Arduino: 1.8.19 (Windows 10), Board: "WEMOS D1 MINI ESP32, 80MHz, Default, 240MHz (WiFi/BT), 921600, None, Disabled"
C:/Users/emil1/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2601/bin/../lib/gcc/xtensa-esp-elf/14.2.0/../../../../xtensa-esp-elf/bin/ld.exe: libraries\WebServer\WebServer.cpp.o: in function `RequestHandler::addMiddleware(Middleware*)':
C:\Users\emil1\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.9\libraries\WebServer\src\detail/RequestHandlersImpl.h:13: multiple definition of `RequestHandler::addMiddleware(Middleware*)'; sketch\TeensyMowerWebControl_ESP32_30072022.ino.cpp.o:C:\Users\emil1\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.9\libraries\WebServer\src/detail/RequestHandlersImpl.h:13: first defined here
C:/Users/emil1/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2601/bin/../lib/gcc/xtensa-esp-elf/14.2.0/../../../../xtensa-esp-elf/bin/ld.exe: libraries\WebServer\WebServer.cpp.o: in function `RequestHandler::removeMiddleware(Middleware*)':
C:\Users\emil1\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.9\libraries\WebServer\src\detail/RequestHandlersImpl.h:29: multiple definition of `RequestHandler::removeMiddleware(Middleware*)'; sketch\TeensyMowerWebControl_ESP32_30072022.ino.cpp.o:C:\Users\emil1\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.9\libraries\WebServer\src/detail/RequestHandlersImpl.h:29: first defined here
rocess(WebServer&, http_method, String)':
C:\Users\emil1\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.9\libraries\WebServer\src\detail/RequestHandlersImpl.h:36: multiple definition of `RequestHandler:
rocess(WebServer&, http_method, String)'; sketch\TeensyMowerWebControl_ESP32_30072022.ino.cpp.o:C:\Users\emil1\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.9\libraries\WebServer\src/detail/RequestHandlersImpl.h:36: first defined here
C:/Users/emil1/AppData/Local/Arduino15/packages/esp32/tools/esp-x32/2601/bin/../lib/gcc/xtensa-esp-elf/14.2.0/../../../../xtensa-esp-elf/bin/ld.exe: libraries\WebServer\WebServer.cpp.o: in function `RequestHandler::addMiddleware(std::function<bool (WebServer&, std::function<bool ()>)>)':
C:\Users\emil1\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.9\libraries\WebServer\src\detail/RequestHandlersImpl.h:21: multiple definition of `RequestHandler::addMiddleware(std::function<bool (WebServer&, std::function<bool ()>)>)'; sketch\TeensyMowerWebControl_ESP32_30072022.ino.cpp.o:C:\Users\emil1\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.9\libraries\WebServer\src/detail/RequestHandlersImpl.h:21: first defined here
collect2.exe: error: ld returned 1 exit status
Mehrere Bibliotheken wurden für "WiFi.h" gefunden
Benutzt: C:\Users\emil1\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.9\libraries\WiFi
Nicht benutzt: F:\Programme\Arduino\libraries\WiFi
Mehrere Bibliotheken wurden für "SD.h" gefunden
Benutzt: C:\Users\emil1\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.9\libraries\SD
Nicht benutzt: F:\Programme\Arduino\libraries\SD
exit status 1
Fehler beim Kompilieren für das Board WEMOS D1 MINI ESP32.
