I add a NP12 7Ah dead lead acid into the battery case to increase the rear weight of the mower (near 2 KG)This looks much better. Thank You @Bernard
I have used the same as you settings for StanleyControl, but a lower mow speed
What speed for the mow-motors you are using? I need to do something with the tyres too, the grip is very bad...
Mow motor speed is set to PWM=210
Here in PJ the list of setting:
