Errors and fault's
After installing the latest firmware, the mower often goes too far over the wire. So far that he no longer reaches the inside of the loop. Today 2 times in less than 60 minutes. The log shows that the Teensy is overloaded. For example, here is the log while charging.
  • TEENSY_BT.txt
This log shows the mower goes too far over the wire while overload.
  • TEENSY_BT (1).txt
This overload is not normal.You never need to see this message.
Certainly I2C bus ?
Maybe you have activate the OLED screen and not connect it ?
Check into setting Rain/temp/screen and desactivate it.
Take a look at the startup console or check that IMU ,all the motor / battery sense and voltage are OK
