Robomow RL500 HELP
markyt
New member
Hi all,
I hope someone can help. I have RL500 robomower. Everything mechanical is working or new. The battery pack when charged outside the mower and then placed in the mower works fine and the mower will function normally. However when I try to charge though the pull out controller I get a malfuntion error with charging. Very frustrating as have to take pavk out to charge. I have changed or check the wiring and changed the controller but with no success. Is this a majm board problem. If so ... an easy fix or try to find another board. What boards will work with this mower. Thanks kn advance
