Can't find ChargeEnablePin on Landrumower PCB V1.01
Sunflare
Member
Hi All,
I'm currently in the state of assembly of all my mower components.
While checking the necessary connections between Landrumower PCB and PowerPCB (1.09.1) I became desperate in my search for the propper counter part of "ChargeEnable" (J5) of the Power PCB. I could not find a suitable (named) connector on the Landrumower PCB.
I also checked the firmware (Micropython) for the RPi Pico and didn't find any hint of ChargeEnable.
Can someone explain the situation to me? (Is it ignored? If so, how is charging controlled?)
Thanks in advance
Thomas
Which Landrumower PCB are you using? It should actually have a 6(?) pin connector on it.
But it's been so long.
Charge enable ist meiner Meinung nach komplett überflüssig, da ein ordentlicher Akku mit BMS das selber mit dem Lader aushandeln soll, da hat Roboter FW nichts zu melden... Auf meinem Power PCB ist das Teil der Platine gar nicht bestückt
