sunray for RPi@landrumower: Lost in confusion
Sunflare
Hi All,
somehow, I have trouble to get the software configuration and installation straight in my head.
I hope someone here is able and willing to help me:
I have
  • the Landrumower PCB
  • A Raspberry Pi 4B
  • A raspberyPi Pico
I would like to run a Mower based on sunray (for Alfred, not OWL) with Cassadra doing the "coordination".
Cassandra and sunray should run both on the RPi 4B
I believe I understood the following:
  • The Pico
  • The RPi with Cassandra:
  • The RPi with sunray (that's my personal challenge)
    • It's supposed to make the low-level control (GPS/RTK, track following, battery monitoring, motor control, ...)
    • I found the information to choose the Repo/branch GitHub - EinEinfach/Sunray at landrumower-linux
    • I cloned it and tried to understand the structure but although I find a subtree Sunray/sunray (with config.h),
      the instructions only tell me to operate in Sunray/alfred (for Alfred) with its config.h.
      But I intend to build sunray (firmware) not Alfred.
My two questions are:
  1. Did I get the structure and functions right as far as I got (if not, please explain)?
  2. What is the proper procedure and repo+path to compile and install a working "sunray firmware" that i can connect to Cassandra on one end and to the Pico-Firmware on the other end for my RPi based hardware configuration? (I didn't see a thread where that part is explained!)
Thanks in advance!
Thomas
