Here a fast description of the motor speed and odometry management.
Unfortunately it's very complex and i am not a teacher
The goal is to accelerate for a compute duration (according the distance to drive) ,run at speed max and reduce speed just before the end of the distance to drive using odometry counter.
PS : Distance to drive give us a total movement duration (use later as movement timeout) according the ticks per second motor calibration)
To do that:
In the :
It is execute only each time state change.
Main code send a distance to drive (stateEndOdometryRight), a speed motorLeftSpeedRpmSet(rpm), and acceleration UseAccelRight (Y/N) or brake UseBrakeRight (Y/N)
For example near line 3878 you can find the code for mower to leave the station.
now OdoRampCompute(); is launched to compute some var.
it 's :
distToMoveRight in odometry ticks
PwmRightSpeed ,the speed in PWM compute using a map function between motorSpeedMaxRpm and motorSpeedMaxPwm
OdoStartBrakeRight the moment when we need to reduce speed.
2 cases, if the distance to drive is > at 1 full rev we start to reduce motor speed at half of the last revolution OdoStartBrakeRight = odometryTicksPerRevolution / 2;
else
we start to reduce speed at the half of the distance to drive OdoStartBrakeRight = distToMoveRight / 2;
movingTimeRight it's in millis the moving max duration of the movement
accelDurationRight it's in millis the accel duration
we use the value from arduremote setting if the movement duration time is > to it or half of the total movement duration.
Now we know all the main movement var :
distToMoveRight
PwmRightSpeed
OdoStartBrakeRight
accelDurationRight
After these setting the main loop find the same select case STATE_STATION_REV: but this time it's execute non stop .
In the example it's near line 7547
here we check if the movement is finish or if a timeout is trig (MaxOdoStateDuration)
motorControlOdo(); is execute each 15 ms and is the most important part to set the speed variation of the motor according all var IMU Yaw etc...
check if the odometry cible is OK to stop the wheel
here the acceleration part according millis and a duration
compute the acceleration speed using the accelDurationRight and a sinusoidal ramp (for a smooth movement ,but a linear ramp is also ok)
here the brake part according odometry and actualy position of the encoder
code start to reduce speed at OdoStartBrakeRight,
All the code locate after is used to change speed of only one wheel to drive straight of limit some speed (sonar ,near wire ,slope etc.....)
@Fürst Ruprecht
To change the acceleration speed and avoid step loose.
You can try.
1 - Into setting arduremote increase motorOdoAccel , but have only result on large movement (total movement duration > the value you have select) ,also pay attention to do a motor calibration to have the var motorTickPerSecond correctly set.
but i thing your issue is not here but only on small movement
2- replace the sinusoidale accel by a ramp
3 - try to increase the small movement duration in OdoRampCompute the distToMoveRight var value, so the code later also increase the acceleration duration.
To do that:
In the :
void Robot::setNextState(byte stateNew, byte dir) {
case STATE_STATION_REV: //when start in auto mode the mower first reverse to leave the station
statusCurr = TRACK_TO_START;
if (RaspberryPIUse) MyRpi.SendStatusToPi();
UseAccelLeft = 1;
UseBrakeLeft = 1;
UseAccelRight = 1;
UseBrakeRight = 1;
motorLeftSpeedRpmSet = motorRightSpeedRpmSet = -motorSpeedMaxRpm / 2 ;
stateEndOdometryRight = odometryRight - (odometryTicksPerCm * stationRevDist);
stateEndOdometryLeft = odometryLeft - (odometryTicksPerCm * stationRevDist);
OdoRampCompute();
break;
void Robot::OdoRampCompute() { //execute only one time when a new state execution
//Compute the accel duration (very important for small distance)
//Compute when you need to brake the 2 wheels to stop at the ODO
//Compute the estimate duration of the state so can force next state if the mower is stuck
stateStartOdometryLeft = odometryLeft;
stateStartOdometryRight = odometryRight;
motorRightPID.reset();
PwmRightSpeed = min(motorSpeedMaxPwm, max(-motorSpeedMaxPwm, map(motorRightSpeedRpmSet, -motorSpeedMaxRpm, motorSpeedMaxRpm, -motorSpeedMaxPwm, motorSpeedMaxPwm)));
PwmLeftSpeed = min(motorSpeedMaxPwm, max(-motorSpeedMaxPwm, map(motorLeftSpeedRpmSet, -motorSpeedMaxRpm, motorSpeedMaxRpm, -motorSpeedMaxPwm, motorSpeedMaxPwm)));
//try to find when we need to brake the wheel (depend of the distance)
int distToMoveLeft;
int distToMoveRight;
distToMoveLeft = abs(stateStartOdometryLeft - stateEndOdometryLeft);
distToMoveRight = abs(stateStartOdometryRight - stateEndOdometryRight);
//left wheel
it 's :
if (distToMoveRight >= odometryTicksPerRevolution) { //more than 1 rev
SpeedOdoMaxRight = PwmRightSpeed;
else
movingTimeRight = 1000 * distToMoveRight / motorTickPerSecond ;
movingTimeRight = movingTimeRight * motorSpeedMaxPwm / abs(SpeedOdoMaxRight);
if (movingTimeRight >= motorOdoAccel) accelDurationRight = motorOdoAccel;
else accelDurationRight = movingTimeRight / 2;
distToMoveRight
PwmRightSpeed
OdoStartBrakeRight
accelDurationRight
motorControlOdo();
if ((moveRightFinish) && (moveLeftFinish) ) {
if ((motorLeftPWMCurr == 0 ) && (motorRightPWMCurr == 0 )) { //wait until the 2 motor completly stop
setNextState(STATE_STATION_ROLL, 1);
if (millis() > (stateStartTime + MaxOdoStateDuration)) {//the motor have not enought power to reach the cible
if (developerActive) {
ShowMessage ("Warning station rev not in time Max Compute duration in ms :");
setNextState(STATE_STATION_ROLL, 1);//if the motor can't reach the odocible in slope
break;
void Robot::motorControlOdo() {
// call to reach a ODO cible on left AND right wheel so they don't stop at the same time accel and slow are used to smooth the movement of the mower
//Stop motor independently when the cible is reach
if (UseBrakeRight && (motorRightSpeedRpmSet >= 0) && (stateEndOdometryRight - odometryRight <= -10)) {//right
moveRightFinish = true;
PwmRightSpeed = 0;
motorRightSpeedRpmSet = 0;
motorRightRpmCurr = 0;
// RIGHT WHEEL
rightSpeed = PwmRightSpeed ; //Normal speed
if (motorRightSpeedRpmSet > 0) { //forward Right wheel -----------------------------------------------------------------------------
// ShowMessage(" FR rotate ");
if (UseAccelRight && (millis() - stateStartTime < accelDurationRight)) { //Accel mode for duration
//Sinus accel
angleCorresp = map(millis() - stateStartTime, 0, accelDurationRight, 0, 89);
rightSpeed = PwmRightSpeed * sin(radians(angleCorresp));
if (UseBrakeRight && (odometryRight > stateEndOdometryRight - OdoStartBrakeRight)) { //Braking mode by odometry
//Sinus brake
angleCorresp = map(abs(stateEndOdometryRight - odometryRight), OdoStartBrakeRight, 0, 89, 10);
@Fürst Ruprecht
You can try.
ramp = map(millis() - stateStartTime, 0, accelDurationRight, 0, 1);
rightSpeed = PwmRightSpeed * ramp);
