Command use 2 button :
RED one to power ON the PCB
Green one to start mowing , after pushing it you have 10 second to close the cover and mowing start, open the cover to stop mowing.
Oled screen is also locate under a transparent plastic sheet to keep the chassis waterproof.
Cover is also reuse with the security STOP button and the original charging contact:
Are all those mower you have, installed on your lawn with stations?
Do you follow the openmower project? Some guys there are reverse engineering yardforce mainboards.
@Sascha :
New pcb is in the mower and work perfect with BL driver
5V protection and capacitor are not actually populate and i don't really need them.
Good job.
Very nice, I wonder how much space is in such a case in vain to the matrix.
I am glad that the PCB's work as they should. A professional developer would probably pull his hair out
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
