Sunray / PI / Teensy
Here you can find my work on the adaptation of SUNRAY firmware for teensy pcb:
From the excellent work of Alexander https://forum.ardumower.de/members/alexanderg.14267/
Repos link: https://github.com/Boilevin/Sunray_TeensyPcb
and the Raspberry PI interface
Repos link: https://github.com/Boilevin/PiArdu-for-Sunray
Without Raspberry:
You use the Sunray APP to manage all the mower over the esp32 BLE .
Max 10 maps
With Raspbery:
You use Sunray APP to create the map and upload it into Rover.
From PiSunray main screen:
and map menu:
You can now import the map in the raspberry.
Max 99 House with 9 map on each house.
The timer page can start mowing on the house and map you want:
Manual page can drive mower (same as azuritber):
On auto page you can see the location on mower in the map and the actual process running:
And using house view you can see the 99 possible house , double click on one map upload it in the rover to start it.
ullisun58
Great work Bernard!
The information of the location of the mower you wrote "On auto page you can see the location on mower in the map and the actual process running:" is GPS-RTK based or ODO metrie based?
It's RTK location at +/- 2 cm when you have a fix.
Odometry and IMU are used to check some error on small movement or when you have a float rtk location.
I try to make a screen video capture of the working mode for easy understanding how it's work when i have time
